ADSL Start Up
ADSL Start Up
Got upgraded this week and all is fine. The problem I have Think I have is that when I go to do my first search / email ,I get asked to connect although all indications are that ADSL is running. Advice please
ADSL Start Up
Just press connect then Cheesy
ADSL Start Up
Fair Enougth but should I have to ? there must be some thing in Explorer set up wrong surly.
ADSL Start Up
Internet Explorer?
If so, try the following:
1. Launch 'Internet Explorer'.
2. Click 'Tools' > 'Internet Options'.
3. Select the 'Connections' tab.
4. Select 'Never Dial a Connection'
5. Click 'Apply' > 'OK'
6. Try searching as usual.
If the above doesn't work, go through the above routine and change #4 to 'Dial Whenever a Network Connection is not Present'.
If neither of the above work, then revert back to the original option.
Regards
Ripperoo
holdtight
ADSL Start Up
If your using a modem and not a router you have to connect first before you can check email/browse thats just the nature of modems whereas a router is always connected
