ADSL Speed
ADSL Speed
Hi All
My DSL connection seems a bit chuggy..
Could some of you guys go here
http://portal.plus.net/my.html?action=tickets
And see what results you are getting, this is what i get.
Starting speed test...
Do not use your connection until the test has finished.
Downloaded 32768 bytes in 641ms
Fairly fast connection, trying 524288 bytes.
Downloaded 524288 bytes in 11500ms
Now starting download test
Downloaded 524288 bytes in 14339ms
Estimated downstream speed is 285Kbps.
Uploaded 133120 bytes in 4359ms
Estimated upstream speed is 238Kbps.
Uploaded 133120 bytes in 4375ms
Overall estimated upstream speed is 237Kbps.
Results stored.
>>> Speed: 285Kbps (down), 237Kbps (up) <<<
Test complete.
Cheers
Nigel G
RE: ADSL Speed
This could be down to a number of things.
One of the issues may be that if you are over 3.5 Kilometres from the exchange your rADSL may download at a lower speed. This is simply due to the distance form the exchange and the quality of the line.
Kind Regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| Technical Support ................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
RE: ADSL Speed
Sorry guys the link is http://speedtest.adslguide.org.uk:8080/speedtest.html
As for the distance, most of the time my rDSL download speed is near the same as my upload speed. Surley if things were that bad then the test would have failed (i was told it did at one point) i was advised by one of your chaps to test this out for a while as i was quite prepaired to have things changed over to my other line (see open ticket) which seems to have a shorter run to the exchange. I don't think i am happy with this D/L speed. (My D/L speed is near half what it should be).
Is there a way we can get the distance of the two lines checked by BT so i can use the best line for the job.
Regards
Nigel G
RE: ADSL Speed
Last time I ran this check on my own plusnet connection it scored well. I will try it again when I get home.
Kind Regards
Kevin
RE: ADSL Speed
Cheers kevin, i look forward to your reply.
Nigel G
RE: ADSL Speed
I get a download speed of 466Kbps
Upload of 237Kbps
should have copied and pasted, but I'm getting tired)
Scott.
RE: ADSL Speed
> Upload of 237Kbps
> Scott.
Cheers Scott
I definate sub standard line here, im getting just above my Upload speed at the moment.
Im getting speeds between 230kbps & 320kbps.
Nigel G
RE: ADSL Speed
> > Upload of 237Kbps
> > Scott.
> Cheers Scott
> Nigel G
Thanks for the link guys, my downstream connection dropped to below 100 kbps for a while last night :eek
Recovered to about 470 later on. Got worried for a while, there...
A.
