ADSL Slow? This may be the solution...
http://server1.ipshosting.com/~geeknewz/comments.php?catid=1&id=2150
I read that getting 90% of rated speed will be as good as it gets:
Downstream 473 Kbps (59.1 KB/sec) 543 Kbps (inc. overheads)
Upstream 243 Kbps (30.4 KB/sec) 279 Kbps (inc. overheads)
1 REPLY
RE: ADSL Slow? This may be the solution...
If you are getting slow DSL speeds then I would suggest you view this:-
http://www.adslguide.org.uk/newsarchive.asp?item=884
It certainly worked for me !
Kezza
