ADSL Routers
ADSL Routers
Has anybody used the Draytec vigor 2200 or 2600 with their plusnet usb modem, or the 2600 connected without the usb modem.
RE: ADSL Routers
Yes, I have the Vigor 2600. Early days yet, but I've had no problems so far. Basic configuration very easy. Even more complex stuff (like port forwarding and allocating IP addresses based on the MAC address) isn't too tricky.
Recommended.
--> Stephen
RE: ADSL Routers
Thanks, just a quick question, what package did you get from plusnet.
> Recommended.
> --> Stephen
RE: ADSL Routers
> John
It took 7 days for our hardware to arrive after the line was activated for ADSL.
Kevin
RE: ADSL Routers
Thanks guys,
I now have the 2600 which is working just fine.
Thanks again
John Ashby
