ADSL Router Reboot
ADSL Router Reboot
Hi
Quickie, I have been have a number of speed issues with my 2mb PAYG connection, recently, just seems to get slower and slower. I find the only thing to do is restart the ADSL Router.
Two questions:
Is it good practice to disconnect from time to time anyway ?
It can take my router about 10 mins and a number of reboots to connect is that normal ?
Nigel
Cloudmaster
Re: ADSL Router Reboot
Based on my own experience I'd say that's far from normal. Mine usually takes no more than about 40 seconds to reconnect after a reboot.
ADSL Router Reboot
Hi
Thanks for that, if that is the case does anyone know if it is likely to be the router or the line ?
What normally happens is that I reboot the rooter it comes up but doesn't connect, sometimes by leaving it it finally connects or I keep resetting it then evventially it will connect.
Nigel
ADSL Router Reboot
1. It is not particularly "good practice" to disconect from time to time - you shouldn't need to.
2. No i wouldn't say that was "normal". If you know what make and model your router is i would visit the manfucturers website and see if you can obtain an updated firmware.
Failing that make sure that your router is not getting too hot - all too often I have gone round to fix "faulty" routers to find that they are sitting on a thick carpet and are almost too hot to touch - this is not good for their general stability!
