ADSL Phone number
ADSL Phone number
I am using my son's old AOL BT Voyager 105 modem.
I have been having problems connection to Metronet tonight and have reported my problem to the support team. I am sure that there will be a lot of similar requests for help.
I am thereore asking for help from this forum.
When trying to solve the problem my "dial up" reverted back to AOL data.
I have my username and password for Metronet, but I am unsure about the Phone number to use. I have a note that the number is "PPOE", which does not work. Is this correct for metronet? If not what is it?
I am no expert on these mattrs but I can usually manage with a little help.
Thanks,
Bob
ADSL Phone number
Hi Bob,
Welcome to the forum.
I'm not a techie either - so until one drops by have you had a poke around on this page for a little help Wink
Good luck
Bill
Metronet problem
Thanks Bill,
Bob
ADSL Phone number
Hi Bill I have sorted the problem out. My fault, messing about with the dial up data when the site went down, thinking that new progs I had just put on had affected the dial up.
Thanks again
Bob
