ADSL PCI card settings
I have been testing mine tonight after having another ping ladden night and found that previously good settings no longer work.
Now I have too use
Rwin 64240 / Windows Scaling Yes / Timestamp Off / Selective ACKs Default / MTU discovery On / Black hole detection On / TTL 128 / MTU 1492
To see the results have a look at
http://www.adp450.plus.com/trace/ADSL-PCI-tests.htm
ADSL @ 288/576 Self Install
IRC.UTCHAT.COM
Usually in #utgames #UT2003chat
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
RE: ADSL PCI card settings
WOW!!
ITS WORKED!
Plusnet, if your listening, listen to this guy because he is the man. Im just relieved that it is fixed and i can use my connection properly.
Now im away to "frag" some unfortunate opponents.
Dave Allan
Holy smoking-20-ping batman!
Nice one Gus, thanks a lot! Cheesy
This is gonna sound lame... but where did u change these settings?
you use DRTCP get it from
http://www.dslreports.com/front/drtcp.html
IRC.UTCHAT.COM
Gus
My modem is not listed in Drtcp I have got 2 entries 1 for my satalite card one for my on lan but none for my connexant modem how do change the settings then
Coley
> Gus
> Coley
Is it a PCI card or router?
If router then you change those settings via the Web interface or cli.
If it is a PCI card then just set both lan and Dialup settings that way as you PC see's it as a ISDN dialup modem
eg http://www.adp450.plus.com/pics/drtcp.jpg
IRC.UTCHAT.COM
> Gus
> Coley
I've just tried those settings. I *think* it's fixed it, but I'm going to give it a few hours before I start smiling like a cheshire cat.
fallingwaters
Hi Gus
I am about to upgrade to ADSL from ISDN and am interested to know what utility you used to get your timings and info, it looks really useful
thanks, Bill
> Hi Gus
> thanks, Bill
Visual Route
http://www.visualware.com/visualroute/index.html
fallingwaters
Hi Gus, thanks for the info, I have downloaded a copy and it works well
Cheers, Bill
> Visual Route
http://www.analogx.com/contents/download/network/htrace.htm
Good trace route program, better than a DOS prompt anyday Cheesy
hmm it's ok if a bit slow especially if you enabled the packetloss option, I've posted that one here and at ISPr in my sig
