ADSL MAX - started well, but has faded
marchhare
About 2 weeks ago- I presume at the start of the 10 day trial period- I noticed speeds of up to 4mbps. From my end everything appeared very stable and workable. However since then the speed has settled at around 1.85- 1.95, which is close to my average speed before the upgrade.
I know that I wont get the full 8mbps- I was delighted with 3!
Is there anything I can do about this? Thanks
Plusnet Staff
Plusnet Staff
I guess it depends, what speed is the line sync'd at and what are the line stats?
This page lists how to get the stats on most hardware:
http://www.kitz.co.uk/adsl/frogstats.htm
If you can also run the BT Speedtest, this will show the throughput rate BT have set for the line
http://www.plus.net/support/broadband/troubleshooting/bt_speed_tester.shtml
Depending on the results there will depend on what you can do. The following page is a useful read:
http://usertools.plus.net/tutorials/id/13
and may help, also do you know if the line has been unstable at all, dropping the connection a lot, since it was maxed?
marchhare
Thanks for that info. I'll post back when I have some stats.
marchhare
Thanks for the Kitz link- the instructions I had followed from another site were hopelessly incorrect!
Here are the results (sorry, I don't know which are relevant)-
PhyTXCellCount = 6009
PhyRXCellCount = 19778
PhyCellDropCount = 0
LocalSEF = 0
LocalEndLOS = 0
LocalSNRMargin = 8.0 dB
LocalLineAttn = 22.0 dB
LocalTxPower = 9.9 dB
LocalFastChannelRxRate = 0
LocalFastChannelTxRate = 0
LocalFastChannelFEC = 0
LocalFastChannelCRC = 0
LocalFastChannelHEC = 0
LocalFastChannelNCD = 0
LocalFastChannelOCD = 0
LocalInterleavedChannelRxRate = 4128000
LocalInterleavedChannelTxRate = 448000
LocalInterleavedChannelFEC = 785
LocalInterleavedChannelCRC = 7
LocalInterleavedChannelHEC = 5
LocalInterleavedChannelNCD = 0
LocalInterleavedChannelOCD = 0
RemoteSEF = 0
RemoteLOS = 0
RemoteLineAttn = 16.5 dB
RemoteSNRMargin = 24 dB
RemoteFastChannelFEC = 0
RemoteFastChannelCRC = 0
RemoteFastChannelHEC = 0
RemoteFastChannelNCD = 0
RemoteInterleavedChannelFEC = 2
RemoteInterleavedChannelCRC = 0
RemoteInterleavedChannelHEC = 0
RemoteInterleavedChannelNCD = 0
BT TEST
IP profile for your line is - 3500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 4128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1865 kbps
In answer to your earlier question, no, the line (phone, skype, web) has been very well behaved.
I have double checked my filters etc.- they're all correct.
sam
Hi
I have made some changes to your account that should resolve your problem. Can you please wait about 10 minutes and then reboot your router and see if the speed increases.
If not you can either PM me, or respond to this thread and I will look into it further.
marchhare
Thanks very much. I've tested a few times since mid-morning and speeds are between 2.3 and 3.3. A great improvement. Cheesy
