ADSL Line Problems
ADSL Line Problems
Traceroute Results: http://cgi.support.plus.com/faultreporting/tracert.php?tracertid=6298635
Traceroute Time (24 Hour): 17:18 to 17:21
Traceroute Duration: 3 minutes
Traceroute Packet Size: 64 bytes
Packetloss in Traceroute?: Yes
Exchange: Newtown
Problem: Other (Please explain below)
Other Problem Experienced: Line is slow, lot of packet loss, very high pings to other ppl.
Duration of Problem: More than 2 weeks
Minimum Speed Achieved On PlusNet Speedtest: 47.6 kbps
Maximum Speed Achieved On PlusNet Speedtest: 800 kbps
Average Speed Achieved On PlusNet Speedtest: 423.8 kbps
Account: ADSL Home Worker - 1mb (20:1)
IP Block Size: Single (default)
Ticket Number: None
Additional Information: None
[Moderator's note (by acarr): HTML not supported. The traceroute output can be seen in the link above]
Moderators note (John) Also all capital Title made lower case. Please do not post in all Capitals
[Moderator's not (by Thomas): Title made more informative to those browsing the forum.]
ADSL Line Problems
HTML code is not suppoted on this message board so you may want to edit the above so it is readable.
ADSL Line Problems
Hmm a few people seem to be posting the information incorrectly. Does the page need to be made clearer?
Ianwild
ADSL Line Problems
Again, this looks like it will be down to BT exchange / local problem - We have just about ruled out any generic problems within the BT network, now that BT have admitted to the main problem we have seen. Do check your exchange at http://cgi.support.plus.com/exchanges/ (Chris, maybe the fault form could allow for the exchange colour status to be entered on the report?) and ensure you raise this information into the Contact Us system. We can then get this logged with, and fixed, by BT.
Regards,
Ian
