ADSL Home Surf
ADSL Home Surf
Hi, I am about to recommend the ADSL Home Surf package to a relative but I need to know whether it supports MSN instant messaging. I know there are some restrictions with this account ( no p2p ) so would appreciate an answer.
Many thanks :?:
ADSL Home Surf
Yes, you can use MSN on this package. However, the advanced feature like voice and video are a little different.
From what I see, these should work, however, even with the better package, people have noted problems with getting these to function (MSN or system configuration issues)
Home Surf and MSN Instant messaging
Great, thanks for your help Philip :lol:
ADSL Home Surf
But ony if you have a router - I have a friend on ADSL Home [the better package] who uses a regular modem and it works fine.
