ADSL Exchange Question
Does anyone know how to find out the distance your phone is from the exchange?
I'd like to find out because the BT availability checker says that I 'may be able' to receive ADSL at my address.
ADSL is not yet available in Devizes, but is only a few months away.
RE: ADSL Exchange Question
Have you tried calling BT?
BT should be able to tell u your exchange address.+ a map.I'm 3.8 mls from mine.
:bandit:
antonywm
> :bandit:
Try This, easest way I know
Dial 17070, select option 3,1 and 2. The system will then check the length of your line and call you back with the result. This test is only a rough indicator and doesnt always work, if you have an ISDN or HH line it wont work at all.
