ADSL 'Dial Up' Times....
Most if not all ADSL modems internal or external establish the ADSL connection with local exchange whilst your PC is booting up and is rarely ever a problem unless there was something wrong with your modem and/or the exchange.
On a good typical day, I can expect the ADSL "dial up" (after modem synch with exchange) to take around 1-5 seconds. On other days it can 'hang' for longer or even fail to connect and retry X no. of times.
Whenever I suspect PlusNet is playing up like long dial up connecting or pages not loading or something else...I try dial up connecting with the BT_Test login.
Can anyone tell me why the BT_Test login puts the PlusNET login to shame in terms of connecting time? - the BT_Test logon is instant literally every single time I do it, why can't PlusNet be like that?
1 REPLY
RE: ADSL 'Dial Up' Times....
Hi!
I have had the same experience with connecting to Plusnet ADSL and have sometimes used the BT_Test name to login and yep it's absolutely quick isn't it.
Melodytune
