ADSL D-link DSL 604 wireless 22Mbps router
Hi All
Can anyone give some feed back on the D-link 604 wireless router ease of setup ,configuation and stability as i am looking to buy one soon.
PS They are well priced at the moment.
Cool
Regards
Rudy
I'd appreciate some feedback too. It's on my list of things to buy once my line is activated.
I have a DSL-604+ (ADSL was enabled on Saturday). The setup and config is relatively easy and straight forward if you have a bit of technical knowledge. If you don't know your LAN from your VPN, it would be worthwhile getting a more IT literate person to help you, but you don't need too much ability.
As far as stability is concerned, I have had a few drops of wireless connectivity, which seems to be a common problem. I have updated it to the latest firmware today, so I will have to see if this has resolved it. The drop in connectivity is only for a few seconds, but it is enough to stall downloads from the Net.
Given the price, the relative ease of use, and unobtrusive look (it is sitting in my lounge) I would recommend this router as a good choice.
Hope this helps.
Thanks for your info on DSL-604+ , are you using a firewall with the 604.
I am at present using Zonealarm pro hope this will be OK with the 604.
By the way what make and type of wireless access point are you using.
Regards Rudy
Cool
I am also using Zone Alarm (not Pro) and it works really well. The DSL-604+ is the wireless access point, so I am unsure what your second question means.
If you are referring to wireless cards, I bought a D-Link DWL-650+ PCMCIA card and a a DWL-520+ ISA card, which work perfectley.
