ADSL Connection Speeds
Traceroute Results: View Traceroutes
Traceroute Time (24 Hour): 08:05 to 08:50
Traceroute Duration: 45 minutes
Traceroute Packet Size: 64 bytes
Packetloss in Traceroute?: Yes
Exchange: Hackney
Problem: Permanently Slow Data Transfer (Everything is slow)
Duration of Problem: More than 1 month
Minimum Speed Achieved On PlusNet Speedtest: 361.80 kbps
Maximum Speed Achieved On PlusNet Speedtest: 460.4 kbps
Average Speed Achieved On PlusNet Speedtest: 411.1 kbps
Account: ADSL Home (Self Install) - 512kb (50:1)
IP Block Size: Single (default)
Ticket Number: None
Additional Information: None
Have you read all the similar threads where advice is given about checking your side of the connection - just look in this and the other forums:
ADSL: Wiring and Filters
ADSL: Trouble Shooting
Try without any other phones connected
Make sure ALL phones, faxes, sky boxes, 56k modems are connected via ADSL filter/splitters.
Try different ADSL filter/splitters, especially the one being used by the ADSL modem - if youare not using a filter for the ADSL modem, use one..
Try your modem directly in the BT master socket.
Have you tried tweaking your MTU & RWIN values - this often helps. See the tweal MTU thread in this forum.
etc etc etc
In addition to the wiring checks and tutorial listed previously.
Have you checked for machine for spyware and adware, trojans?
Do you get disconnection problems? like when the phone is used?
360 to 460kbps speed is not excessively slow for a 512.
Chances are it is a tweaking issue (MTU & RWIN).
the exchange is green status, but is a busy exchange, so it could be contention.
