ADSL Conexant 4 Port router (AMX-CA64E) setup?
Hi All,
Well I recieved this router a couple of days ago, and have had endless trouble trying to configure it. To make things worse, while rebooting the router, it somehow locked me out of the Admin acount. I've since recieved info about unlocking it !!!.
Has anyone else got this router? if so could you please give me some pointers, as to how I should go about setting this router up.
I Had my plus.net connection activated about 2 weeks ago and I still hav'nt been able to connect to it - rather irritating!
Rich
elton
RE: ADSL Conexant 4 Port router (AMX-CA64E) setup?
This is quite a good guide to how to set up the AMX-CA64E:
http://www.cazart.plus.com/conexant/
Mine wouldn't work at all with a normal lan cable - I had to use a crossover cable. But if you're able to ping it, and view the configuration pages, you're halfway there. The manual that came with it is rubbish, but a complete (manufacturers) manual can be downloaded from
http://www.amigo.com.tw/download.htm.
Skonko!
BoneMan
> Skonko!
Rich,
You might also look at http://www.thecaretaker.org.uk/amx.htm and/or look at the forums on http://www.adslguide.org.uk/ and do a search on "AMX" (sans quotes). There's mountains of stuff in there.
BTW, AFAIK you only need a Xover cable if you have the CA*61*E - the single port jobbie. The CA*64*E (4 porter) will work quite happily with a regular cable - at least mine does Smiley.
If you're still struggling come back and I'll post my +Net specific settings for you.
BoneMan
Thanks all for your help,
I have now got it to work at last...!!
Thanks again Rich
BoneMan
Nice one - enjoy Smiley
BoneMan
