ADSL Activated - NO Filters - Phone work as normal ???
Hello,
I order Broadband internet from PlusNet. ADSL Tracker and I got email from Plus.net informing me me that my ADSL ready (24.10.03) Cheesy . I didn't buy ADSL modem yeat.
Before and for a while I am using Dialup conection from Freeserve to conncet to ineternet.
So now I am wonderning: If I don't have filters connected to BT line should I be able to use phone (becouse now phone have normal signal, I can phone like before)?
Or is it means that in reallity my line isn't activated for ADSL? :?:
I think you won't have any interference on the line until you plug in some ADSL equipment. But I'm not 100% sure.
Plusnet Staff
Plusnet Staff
Under normal cicumstances you'll only need the filters on the line once the modem is connected as it is the modem that will generate the noise rather than the ADSL just being on the line.
If the phone is a modern one you may not need any filters. Mine works better with no filters than with them.
Dont worry if it work what the heck
