ADSL 2mb
ADSL 2mb
How come when I did the test on the line for Bulldog it says I can get 2mb connection, but when I go to BT and check my No it says I "cant" get broadband (I've had it with +net for last 6 months)
RE: ADSL 2mb
Hi There,
If you already have broadband, the BT Checker will say you can't get it, whereas Bulldog use Datastream or their own Backhaul / LLU (Depeing on where you are?).
If you want to know whether you can get 2MB DSL the best thing to do is to request a Whoosh test by Contact Us. The results of that will be the best guide in determining suitabilility for higher speed products.
With Regards,
Ian Wild
PlusNet Customer Support
RE: ADSL 2mb
> With Regards,
> Ian Wild
Cheers Ian
