AARGH - port forwarding on alcatel adsl router
I signed up for the plus.net home self install package with the starter package. I cannot find out anything about how to disable the routers internal firewall so i thought i'd try to forward the ports i use when programming my own online applications in macromedia director to my local PC's IP
when i log into the routers setup page in explorer i can choose port forwarding - but it only lets me forward to the IP of the modem with a the option to change only the final number.
ie
routers ip = xxx.yyy.zzz.aaa
possible forward to ip = xxx.yyy.zzz.Huh
where the x,y,and z's are all fixed and the Huh is the changable number. My PC's IP is completely different to this.
so i want to know:
a) how can i turn off the firewall or
b) how do i forward to my computers local IP
thanks
RE: AARGH - port forwarding on alcatel adsl router
im looking for the same sort of thing
found this site for a different router may be some sort of use for info
http://www.linksys.com/tech_helper/advanced.html
I dont know which of the Alcatel routers that you guys have, but I would suggest going to
http://www.speedtouchdsl.com/support.htm
and downloading the relevant PDF.They have a lot of technical info on the site that doent come with the unit.
Hope thats some help
Ian
> ie
> so i want to know:
> thanks
If you are using an Alcatel Speedtouch pro router
then telnet to 10.0.0.138 which is the default ip address of this type of router if you have changed it then telnet to that address instead.
Im afraid you will have to telnet as this function is not available via the browser interface.
Issue the following command within telnet
nat defserver addr xx.xx.xx.xx
where xx.xx.xx.xx is the ip address of your ethernet card that connects to the router.
This command forwards all your traffic to xx.xx.xx.xx ie your PC in most cases
If you do this, then please ensure that you have a good software firewall such as Kerio Personal Firewall.
The above will probably work for other Alactel dsl routers but i make no guarantees Smiley
Ali
