A360 and EMail
A360 and EMail
I've just installed the A360 USB modem, and the connection works - but.... both Explorer and Outlook (express) see the connection as dial-up AND Explorer works, once you put in the ADSL user name (rather than the one I signed up with), but Outlook won't play at all....
It decides to try and dial, and fails the login. Not knowing which user name to use doesn't help, but I also can't find out how / where to tell the system that it is a permanent connection.
Anybody help ?
Brickinit
RE: A360 and EMail
if you go to customer support,technical,services quick start e-mail set up you should get all the info you need. also somewhere on the portal there was a small program that would self configure you e-mail account but i cann't remember where it is but i shall have a look around
malc
> Anybody help ?
Saltire
RE: A360 and EMail
> malc
> > Anybody help ?
If you select Tools in the Outlook menu, then Options then Connection you should be able to change your connection type from dial-up to Wip Tech.
Hope this helps, as it's what I had to do.
