8mb...when will it happen
Anyone know a site that i can check when 8mb will be in my area?
I found a site that just tells me that 8mb aint available.
ta
darren
1 REPLY
darren,
Unfortunately there is nowhere that will tell you when. If you are enabled a normal check will show this.
I refer you to THIS THREAD for a list of enabled exchanges at present with more due soon I believe.
Regards,
