8mb Upgrade
8mb Upgrade
So i asked to be upgraded to 8mb and have just finished the 10 day period i believe, im not sure, I didn't count but it's over 10 days I think..
Anyway, my speed is clocked at 6.9mbps and my speeds are still at 2mb speeds, just under infact(1756.7 kbps).
My question is what does this mean? I can't get higher speeds? I thought it might be my Modem but it does upto 8mb(Alcatel speedtouch)
Any ideas? Smiley
Liam
8mb Upgrade
I have made a profile change at our end. This should improve your speeds. Please let me know if this helps.
8mb Upgrade
It doesn't appear to have improved them im afraid, I did a speedtest on here and my speed was 238kbps but i tried others and they were all around below. Sad
Liam
8mb Upgrade
You will need to disconnect and then reconnect.
8mb Upgrade
I did that. Smiley
8mb Upgrade
Well, speeds are still 2mb'ish... Any ideas?
I'm still getting disconnects aswell.
8mb Upgrade
Bump? Issues are still here. :roll:
