8Mbit on Binatone ADSL 500 modem?
Will the Binatone ADSL 500 modem be able to handle an 8mbit line?
1 REPLY
Yes it should do - the box spec's say that it can handle "Transmission speeds of up to 8Mbps downstream and 1Mbps upstream".
In reality though, even if your line "sync's" at 8Mbps you may still only expect to see data rates around 4Mbps using a USB modem - this is what I've read.
Of course 4Mbps (if your line/connection can provide this, and PlusNet/BT/etc aren't congested with traffic) is still plenty fast enough to handle just about anything.
