8Mb connection and low speeds
I should be on an 8Mb connection, but this is the line information that my Belkin F5D9630 router displays. Have also tried a Linksys WAG54G which has the same speed issues. Only getting a maximum download speed of about 29kb.
Downstream | Upstream
Data rate (Kbps)______ 284 | 287
Noise margin (dB)____ 25.8 | 22.0
Output power (dBm)___ 972.8 | 12.0
Attenuation (dB)______ 64.5 | 31.5
Any ideas on how to get this sorted out?Huh
1 REPLY
Jbalke,
I set up the same router yeseterday and it come up with similar figures. I have no clue but I'm investigating...
did you have any joy more recently ?
thanks
