8 meg upgrade
8 meg upgrade
I have been a customers for a long time and I am still on 2 megs. i have raised a ticket to upgrade to 8 meg after a week nothing had happened.
I raised another ticket but it has now been another week and still I am on 2 meg.
How can I get my upgrade which i should have had months ago as i am paying the full price for only 2 meg
bikepump
8 meg upgrade
i put in my upgrade request last Monday cgrey.
from my understanding regardless of when you put in your request, the request will be processed on the next Friday, ie. mine should have been processed yesterday. From then on it will take BT around 7-10 days for line testing, in this space of time it's a good idea to keep rebooting your router (if you have one) forcing it to re-sync and get you the fastest speeds possible.
basically :
apply for request - Monday 26th
Request processed - Friday 30th March
Line upgrade complete - Friday 6th to Mon 9th
hope you can understand Cheesy
bikepump
8 meg upgrade
BT can still take 7 -> 10 days to action a Max upgrade request and only when the upgrade has been done does the 10 day trialling period start.
8 meg upgrade
BT can still take up to 7 days to action a Max upgrade request and only when the upgrade has been done does the 10 day trialling/testing period start.
Plusnet Staff
Plusnet Staff
Fixes: 159
8 meg upgrade
@cgrey
Your upgrade request has completed, we were waiting for the system to update internally. I've done this manually instead of waiting and you should be seeing higher speeds from now.
 Chris Parr
 Plusnet Staff
8 meg upgrade
I don't know if it's previously been mentioned but you'll need to restart your modem/router in order to see the higher speeds.
Plusnet Staff
Plusnet Staff
Fixes: 159
8 meg upgrade
oops yes sorry, forgot to mention that part. Thanks lestones/
 Chris Parr
 Plusnet Staff
