60.5 dB on the Local Line Atten. Setting
I'm using a SolWise110 router to connect to ADSL 512 and I'm getting a value of 60.5 dB on the Local Line Atten. setting. Is this as bad as it looks?
It used to be about 52.0 dB.
Shocked(
Many thanks.
Jim
RE: 60.5 dB on the Local Line Atten. Setting
How did you find out this value, curious as to see if mine has crept up (again).
It's on the button "DSL Param" under WAN \ DSL on the Sol110 Router html Config Manager.
Cheers,
Jim
