5861 router
5861 router
Hello Forum,
I'm having problem with my 5861 router once or twice a week my coonection disconnects and i allways have to reboot the router in order to reconnect it
please see log below ,,
Why does it not auto connectHuh??
# system log start
Begin System log.
POST summary: successful
Initializing the system RAM ..... done
Initializing optional hardware: "DMT2-ATM:1.7"
Hardware "ADSL DMT-2" successfully initialized -- ID: 480F
Today is Monday March 1, 2004; the time is 20:55:23
My MAC address is: 00:20:6F:13:64:78
Reason for this reset: power up
Trying to boot from flash memory
loading .............................................................................................done.
Verifying CRC (F2C1FF6F).......................................................done.
Efficient Networks, Inc. 5861 (P/N 060-5861-003), Rev 47-10 (S/N 1270904)
Now 2329k free before buffers
Interfaces detected:
LAN: Ethernet (10BASET HUB) WAN: ADSL (DMT)
Efficient 5861 DMT Router (5861-001/2) v5.3.0
Copyright (c) 1999-2000 Efficient Networks, Inc.
All Rights Reserved
INIT: buffer pool is 1380004 bytes
ETHERNET/0 interface started, MAC=00:20:6F:13:64:78
Efficient 5861 DMT Router (5861-001/2) v5.3.0 Ready
Login: 03/01/2004-20:55:43CheesyMT: Line Opening...
03/01/2004-20:55:58CheesyMT: Line Open: Downstream: 576 Kb/s Upstream: 288 Kb/s
03/01/2004-20:55:58CheesyOD: connecting to <internet> using 0*38 over ATM-VC/2
03/01/2004-20:55:59TonguePP: remote <internet> will authenticate
03/01/2004-20:56:02CheesyOD: link to internet over ATM-VC/2 is now up
03/01/2004-20:56:02TonguePP: Peer not negotiating `BNCP' right now
03/01/2004-20:56:03TonguePP: Peer not negotiating `CCP' right now
TN [192.168.254.2:3817] connection accepted..
03/04/2004-04:09:52TonguePP: remote <internet> does not respond to echo. Link closed
MLP: No active link
MLP: No active link
MLP: No active link
MLP: No active link
MLP: No active link
MLP: No active link
MLP: No active link
MLP: No active link
MLP: No active link
MLP: No active link
MLP: No active link
MLP: No active link
MLP: No active link
MLP: No active link
03/04/2004-04:10:08CheesyOD: connecting to <internet> using 0*38 over ATM-VC/2
03/04/2004-04:10:47CheesyOD: connecting to <internet> using 0*38 over ATM-VC/2
03/04/2004-04:10:51TonguePP: remote <internet> will authenticate
03/04/2004-04:11:11TonguePP: Remote <internet> on ATM-VC/2 didn't authenticate in time
03/04/2004-04:11:13CheesyOD: connecting to <internet> using 0*38 over ATM-VC/2
03/04/2004-04:11:13TonguePP: remote <internet> will authenticate
03/04/2004-04:11:33TonguePP: Remote <internet> on ATM-VC/2 didn't authenticate in time
03/04/2004-04:11:35CheesyOD: connecting to <internet> using 0*38 over ATM-VC/2
03/04/2004-04:11:37TonguePP: remote <internet> will authenticate
03/04/2004-04:11:57TonguePP: Remote <internet> on ATM-VC/2 didn't authenticate in time
03/04/2004-04:12:00CheesyOD: connecting to <internet> using 0*38 over ATM-VC/2
03/04/2004-04:12:02TonguePP: remote <internet> will authenticate
03/04/2004-04:12:22TonguePP: Remote <internet> on ATM-VC/2 didn't authenticate in time
03/04/2004-04:12:24CheesyOD: connecting to <internet> using 0*38 over ATM-VC/2
03/04/2004-04:12:26TonguePP: remote <internet> will authenticate
03/04/2004-04:12:37TonguePP: remote <internet> didn't accept our CHAP password
03/04/2004-04:12:40CheesyOD: connecting to <internet> using 0*38 over ATM-VC/2
03/04/2004-04:12:41TonguePP: remote <internet> will authenticate
03/04/2004-04:13:01TonguePP: Remote <internet> on ATM-VC/2 didn't authenticate in time
1 REPLY
5861 router
I don't know that router but does it have an idle timeout option where you can set a time (usually minutes) after which the link will be dropped if not activity is seen. If so set it to 0 so it never disconnects.
You may also want to check the manufacturers website to see if an updated firware version is available.
Also check out the troubleshooting guide on the customer support web page and the wireing and troubleshooting tutorials in the tutorials and FAQs forum to make sure things are configured and wired up correctly.
Could the drop coinside with an incoming or outgoing call? in which case it could be an unfiltered phone or a bad ADSL filter. If you router does not connect through a ADSL filter try that.
