512k to 2mb= now get packet loss in games
I play ut2k4 on jolt servers, i never had a problem with packet loss when gaming on 512k, but ever since being upgarded to 2mb i now get horrible PL when gaming, ranging from 2-15 PL.
any ideas?
im using a 15m telephone extension cable, dunno if that makes a difference, could a better quality cable improve things?
1. check your MTU / Rwin are set for 2mbit
2. try forcing the UT netspeed if you have it on auto detect, have the netspeed as high as possible with no packetloss
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
i have:
mtu= 1492
rwin= 65535
Yes that length of extension cord could make a difference. I was going through a period of my connection dropping rather frequently when it was through a 15m extension. Plugging it into the main BT socket sorted it. A long extension lead will make even more of a difference if you're already on a long/noisy line. Check your SNR/Noise Margin and Attenuation figures if you can. You're looking for a low Attenuation (less than 45-ish for 2mbps lines IIRC) and high SNR/Noise Margins (more than ~10. apparently ADSL won't work with a noise margin below 6).
Just foundout that 2moz my contention ratio goes from 50:1 to 30:1, this should improve my online gaming experience and reduce packet loss and pings i believe.
Fingers crossed Smiley
Still have the pl problem Sad
Used winMTR, my results with plus.net and two game servers:
plus.net
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| lo0-plusnet.pth-ag3.plus.net - 0 | 195 | 195 | 0 | 15 | 31 | 16 |
| gi1-2.802.pth-gw4.plus.net - 1 | 195 | 194 | 0 | 15 | 16 | 16 |
| gi5-0-22.pth-gw2.plus.net - 3 | 195 | 191 | 0 | 15 | 16 | 15 |
| atm0-1-0.ptb-gw1.plus.net - 1 | 195 | 194 | 15 | 21 | 282 | 15 |
| vlan18.sec.ptb-gw4.plus.net - 1 | 195 | 194 | 15 | 17 | 32 | 16 |
| if2.ptb-al1.plus.net - 1 | 194 | 193 | 15 | 18 | 32 | 15 |
| portal.plus.net - 0 | 194 | 194 | 15 | 18 | 32 | 15 |
|________________________________________________|______|______|______|______|______|______|
WinMTR - 0.8. Copyleft @2000-2002 Vasile Laurentiu Stanimir ( stanimir@cr.nivis.com )
jolt ut2k4 server 82.133.85.27
| WinMTR statistics |
| lo0-plusnet.pth-ag3.plus.net - 0 | 201 | 201 | 15 | 17 | 265 | 16 |
| gi1-2.802.pth-gw4.plus.net - 1 | 201 | 199 | 0 | 14 | 16 | 15 |
| ge1-0-0-23.ptn-gw1.plus.net - 2 | 201 | 197 | 0 | 15 | 47 | 16 |
| lon1-10.nildram.net - 1 | 200 | 199 | 0 | 15 | 47 | 16 |
| 84.12.225.130 - 2 | 200 | 196 | 0 | 15 | 63 | 15 |
| jolt-gw.nildram.net - 3 | 200 | 195 | 0 | 15 | 32 | 15 |
| 82.133.85.27 - 2 | 200 | 196 | 0 | 15 | 31 | 16 |
dutch gothica server 217.148.191.122
| WinMTR statistics |
| lo0-plusnet.pth-ag3.plus.net - 2 | 189 | 187 | 0 | 16 | 47 | 16 |
| gi1-2.801.pth-gw3.plus.net - 1 | 189 | 188 | 0 | 15 | 47 | 16 |
| ge0-0-0-22.ptn-gw1.plus.net - 2 | 189 | 186 | 0 | 16 | 63 | 16 |
| ge-0-2-0-0.lonth-inter-2.interoute.net - 2 | 189 | 186 | 0 | 15 | 16 | 16 |
| PO2-0.lon-wal-core-1.interoute.net - 2 | 189 | 186 | 0 | 22 | 203 | 16 |
| PO1-2.rtm-vla-access-1.interoute.net - 2 | 188 | 186 | 16 | 18 | 31 | 16 |
| 212.23.59.170 - 2 | 188 | 186 | 16 | 19 | 31 | 16 |
| so-0-2-0.M160.RTD.we-dare.net - 1 | 188 | 187 | 15 | 22 | 78 | 16 |
| 217.148.191.122 - 0 | 188 | 188 | 16 | 19 | 31 | 16 |
when i was on 512k i had no pl, but when my line went to 2mb games would average 2-4 pl, with spikes of 15 sometimes.
[Moderator's note by Liam Martin (martinfamily): Inserted 'Code' Tags.]
aijain - its only 30:1 on plusnet's network
it'll still be 50:1 on the bt network and it tells u this somwhere.
Do u have line stats handy? Mainly SNR figures + any error figures ur router/modem may report?
Do a speed test a few times and make sure plusnet have untrottled ur accounts connection from the old 512
when line was upgraded to 2mb i had to contact them to unthrottle my account which they did, had nice 2mb con for a while, just did a test today and realise im still getting random speeds below 1mb even, look slike they have some kind of problem with the throttle.
I have a feeling these packet loss issues are just a sympton of what evers going on at plusnets end.
