512 or 1 Mb???
512 or 1 Mb???
Just got this info from my Voyager 105 USB modem.
Does any of it mean that I could get 1 Mb connection rather than the 512 that I am on at the moment?
Startup State: Data Mode
Startup Progress: Completed (0xad)
Last Failed: 0x00000000
Bit Swap Counter: 0x00000002
DSP Firmware Ver: Y1921
Local Coding Gain: 3.5
Remote Vendor ID: b5-00-54-53-54-43-01-00
Remote Vendor Rev: ad-00-00-00
Annex Type: Annex A
Data Rate (Rx/Tx): 576 / 288
Line Rate (Rx/Tx): 608 / 320
Heading: Local / Remote
Attenuation (dB): 55 / 31.5
SNR Margin (dB): 9 / 9
512 or 1 Mb???
1Mb may be fine and 2Mb is out of reach (requres 43dB). Although a 9dB SNR is a tad low and may be a problem at 1Mb - when the speed increases, the SNR often decreases and anything below 10dB is considered marginal for reliability.
FYI it's the local (= downstream) figures you are interested in.
Also see ADSL: Understanding Line Loss and measurements which explains what the dB figures mean.
512 or 1 Mb???
Thanks for the link. Explains it all for me now.
