510v4
510v4
HI
when i set up the router speedtouch 510v4 i used the wizard and selected dynamic, should i have used the static address option
LiamM
510v4
Dynamic simply means that it will be assigned the IP address by Plusnet.
This is not a problem, as Plusnet will assign your router with the right one, your one, and all the correct DNS settings.
Do not worry! All is fine!
510v4
many thanks
