4 ip block
4 ip block
hello, just a small question. if you have a 4 ip block, meaning 2 are usable, what exact purpose do the other 2 ips serve ?Huh
1 REPLY
4 ip block
The other two are used for network and broadcast purposes. You dont really need to worry about them. It's the two in between that you can use, the second is usually assisnged to your router.
Chris
