3com ADSL router connection problems
I have got one of the 3com routers and I am having BIG problems connecting to the internet. It synchronises fine, but takes ages to connect. Last week it two two hours, today it has been on for 10 hours and not connected at all.
Are there other people out there with similar problems or is it just my router/exchange?
RE: 3com ADSL router connection problems
It's a well known problem at the Plusnet forums caused by a bug in the routers firmware that prevents it connecting.
The fix is to log into the router control panel and in the connection settings screen, simply click modify without altering any settings. The router will then connect in a few seconds.
Plusnet are replacing all the 612 routers with solwise I believe shortly.
I've found the same solution (modify settings) but hadn't got round to nagging +net yet. Just a minor irritation at the moment as the line has dropped twice only in 3 weeks.
