33dB noise on d'stream
whats this mean?Huh
RE: 33dB noise on d'stream
> whats this mean??
A bit more info would help.
Where is this figure from?
I would hazard a guess that it could be 33db Signal to Noise Ratio measured on the downstream signal but without knowing where the information is from then its just that, a guess.
Regards
http://www.hmrg.co.uk
okies cheif here goes ope you understand this one a bit more,,,,
my adsl control panal has a thing in it Tongue
Status--------------------------------------
---------------------up--------------down-
niose margin--21.0Db--------27.0Db
Attenuation------19.0Db--------38.8Db
bits per frame----223-------------2112
MAxuimum Tx PSD -38 Db/Hz
Starup up atempts 22
The figures you have posted show a pretty good line with a decent signal to noise ratio.
They mean that in the worst case your signal is 21dbs above the noise level or in real terms over 100 times stronger than the noise.
attenuation levels for up and down are well within the limits needed for 512k ADSL.
i have 2 meg,,,is this good for 2 meg,,,,,i do get click click modem relay all the time,,,,is this called getting disconected
From the ADSL Guide site
Line Loss (They need to ensure your line has suitable quality for ADSL), You need a line loss of no more than 41db for 1Mbps & 2Mbps products, 60dB for 512kbps products.
The above shows that your line should be good for the 2 meg version.
Why you are getting the cutting off I don't know.
Have you tried the fault finding guide from the Tutorials section of the forums?
In particular what happens if you connect directly to the master socket with no other apparatus connected to your line?
wher did u get those measurements from, and how can i test my line?
cheers
If you want a quick and simple method to get the details, use the link:contact us system and request a Whooosh test
Many modems and routers have this function built in and will show you the line loss and noise figures by going into the menu.
If I request a whoosh test can I find out the reading for my line ?
thanks
See the other thread where you have asked the same thing.
Hi, would I be able to get line reading details on my line via a Whoosh test although I dont have ADSL?
No - Unloess you allready have ADSL, you can't have a whoosh test performed.
Once you have ADSL, only the ISP providing your line can perform the whoosh test.
