3 or 4 Times to connect
Why does it take 3 or 4 times to connect on most occassions ? - I have to physically disconnect and then re-connect. Does anybody else experience this and know why it happens ?
Cheers
JASON
RE: 3 or 4 Times to connect
Set up your login so it automatically dials the number of attempts you specify. You can also set the time intervals between dial ups.
You shouldn't have to ADSL should connect first time, everytime.
