2mb upgrade?
obitus
2mb upgrade?
First off.. sorry if this has been posted before.
Just wondering if i upgrade to a 2mb connection (currently 512kb) will this be activited straight away or will there be a period when i would be unable to have internet access. Again sorry for the newbie type question.
1 REPLY
2mb upgrade?
You wont notice any downtime as its normaly in the night and then for half an hour. When I did it it was upgraded in under 2 days.
Dont forget to change your account to the cheaper option if you are an old customer
