2mb possible ????
2mb possible ????
using a speedtouch usb jobby with dr speedtouch got these figures
am currently on 1mb but obviously want 2mb, so if anyone wants to translate
would be much appreciated Cheesy
ErrorredSeconds= 0
LossOfFraming= 0
LossOfLink= 0
LossOfSignal= 0
PhysicalLinkStatus= Up
ReceiveAttenuation_dB= 48
ReceiveMargin_dB= 27
RxOutputPower_dBm= 0
SendAttenuation_dB= 30
SendMargin_dB= 23
TotalBytesReceived= 10706
TotalBytesSent= 34026
TotalPacketsReceived= 389
TotalPacketsSent= 389
TxOutputPower_dBm= 0
Uptime= 2018
ChannelMode= Fast
Layer1DownstreamMaxBitRate= 1152000
Layer1UpstreamMaxBitRate= 288000
WANAccessType= DSL
2mb possible ????
First is download line attenuation, 2nd in download SNR (signal to noise ratio)
For 2Mbs you need a line attenuation of 43dB or lower, so for now 1Mb is all you can get.
2mb possible ????
hmm 5dB difference, is that possible to fix or am i Sad
thanks for your help
2mb possible ????
your Sad
However romour has it the line limits may be relaxed again soon so 2Mbs may be possible in the future, especially as you have a very good SNR figure.
Wait and see what April brings.
2mb possible ????
cheers matey heres hoping :roll: Wink Cheesy
2mb possible ????
Btw! could somebody tell me how i can check my line attenuation and all the other thingy stuff. Do i need an app?Huh
2mb possible ????
Some routers and USB modems will tell you your current line stats as has been posted above) but not all will. So check you router / modem to see if it shows anything
You can find out your line attenuation out by asking PlusNet to do a whoosh test but many people have been asking for this recently and slowing down the resolution of fault investigations they do - each whoosh test takes 15 mins - so I would recommend you don't ask for this at this time. unless you do have a problem.
Come April when you're changed to MaxDSL you will be able to find what speed your line is capable of anyway so I suggest you just wait until that time.
2mb possible ????
I have a belkin wireless router model number F5D7630 but i could'nt find anything on there.
Sure i can wait til april anyway Smiley
Thanks for your reply Peter.
2mb possible ????
That router does not show line stats.
mjerome
2mb possible ????
The F5D7630 does show line stats but the page is undocumented.
Try http://192.168.2.1/ADSL_status_main.stm
2mb possible ????
I have browsed this utility but cant find owt Cry
Btw Peter in April do we get an e-maill telling us that our line speed has been upgraded, or do we have to contact PN about upgrade?
2mb possible ????
No idea.
2mb possible ????
LOL - another reboot of the router of mine and its dropped again.
Started at attenuation of 57dB
Rebooted a couple of days ago and it dropped to 56dB
Rebooted again today and its now 55dB
My SNR has risen steadily too - now at 26.5dB :shock:
I reckon there is a ferret running up and down the conduet housing the cables and giving them a good polish!
As the houses round here are only 5 years old at most, all the lines from here to the local green box are fairly new - I reckon that has to be helping me gain a SNR of 26.5
Reading a post by someone who has 2mb with attenuation of 56db and SNR of 16dB, Im starting to cross my fingers that the SNR I have will help me get it too!
2mb possible ????
I think many people will start to see their attenuation get better as the weather dries out - damp and electrical circuits dont mix well.
Good Job BT are starting MaxDSL in April - hopefully the weather will be a bit warmer and drier than it is now...
