2mb line
2mb line
I detailed previously problems I have had with my 2mb line.
As I got more frustrated I decided to experiment to see if there was a prob on the line.
My router reported a noise margin of 13-14db on the downstream. Plusnet said this was ok...
However, after unplugging I unplugged my sky plus modem cable the noise margin jumped to 24db! Can anyone confirm is this is a good noise margin? Other stats are power 10dbm upstream, 20dbm downstream and attenuation 16d up, 32db down.
One other thing I didnt know was that all devices should be plugged through a microfilter. The sky modem was directly connected to the socket. Should I therefore buy a filter? Will this improve the signal? Can I plug the sky modem back in then with the filter?
My DECT phone doesnt seem to affect the noise margin though! Stays at 24db whether in or out of the socket.
Any suggestions?!
Thanks,
Dan
2mb line
And can anyone explain these stats in my router?
Indicator Name
Near End Indicator
Far End Indicator
Fast Path FEC Correction
0
0
Interleaved Path FEC Correction
0
0
Fast Path CRC Error
4
2
Interleaved Path CRC Error
0
0
Loss of Signal Defect
Loss of Frame Defect
Loss of Power Defect
Fast Path HEC Error
1
1
Interleaved Path HEC Error
0
0
2mb line
Ok, 24dB is very good.
Yes all phones, faxes, sky boxes, 56k modems etc must all be connected via a filter i.e. anything that was connected to your phone system should now go through an ADSL filter. I am not surprised the sky connection caused your problems.
The figures in your 2nd post are just stats for line losses, crc errors etc - a bad line can be seen if the various figures show high numbers (100's, 1000s etc). As they are all low or 0 it means you connection is very good and there is nothing interfering with or corrupting the data being transmitted or received.
So once you have a filter for your sky connectio (and any other equipment I mentioned above) you should not have any problems.
The best filter to use is this one.
