2mb Service Drop...
sophos9
2mb Service Drop...
Hi
How do these results look for a 2mb service?
Date Speed Achieved (kbps)
11-08-2005 21:44:50 1211.6
11-08-2005 21:42:16 759.8
11-08-2005 21:41:55 1043.3
11-08-2005 20:11:00 1579.3
11-08-2005 20:09:44 930.5
11-08-2005 19:57:50 1766.9
11-08-2005 19:51:55 1008.2
11-08-2005 19:51:04 927
11-08-2005 19:49:35 923
11-08-2005 19:49:13 694.1
08-08-2005 18:05:40 1933.8
04-08-2005 20:04:58 1725.5
04-08-2005 20:04:38 1270.9
04-08-2005 20:04:17 1333.6
04-08-2005 20:03:32 1512.1
26-07-2005 18:40:21 1870.4
10-07-2005 21:08:44 1904.3
07-07-2005 18:22:23 1925.6
30-06-2005 15:49:02 507.8
+net states there are no problems....
Is anyone else having this problem....?
2mb Service Drop...
Some of those speeds are pretty poor.
What does the exchange checker show?
Are those tests from the BT speed tester?
sophos9
2mb Service Drop...
Hi
Tests are from the plusnet bandwidth checker...
VP capacity at this exchange is currently showing as Green.
Click here for further details
VP Port capacity at this exchange is currently showing as Green.
Exchange has no known issues....
Can anyone help....
2mb Service Drop...
Run a couple of BT Speed tests and post the results.
That will identify if the problem is BT or Plus Net.
sophos9
2mb Service Drop...
Hi
Speed test ran and looks perfect!
Im on a small exchange probably about 100 users
Results:
1946 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
1950 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Perfect results for 2mb!!
Ran Plusnet Bandwidth today...
12-08-2005 13:52:25 1937.4
12-08-2005 13:52:02 1942.3
12-08-2005 12:52:50 1928.2
Hmm..... contention? Traffic shaping?... Any help would be great!
2mb Service Drop...
As both sets of results are good today, its hard to know what the previous issue was.
If it happens again, run both BT and PN speed tests and add them to the post.
sophos9
2mb Service Drop...
Service bad again today
Exchanges show all clear
Plusnet Bandwidth Checker:
13-08-2005 11:48:26 1301.8
13-08-2005 11:44:58 1205.7
13-08-2005 11:44:42 1133.7
BT Speedcheck
1232 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
985 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
1009 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Guess the problem is with BT.... What do you think?
Thanks for all the help!
2mb Service Drop...
Yip. looks like an exchange / contention issue. Unfortunately your speeds arent quite bad enough yet for BT to sit up and take notice.
Keep an eye on it and log the speeds. If it worsens then report it.
sophos9
2mb Service Drop...
Thanks for the quick reponse....
Are you talking network congestion or exchange congestion? Seriously, I live in a tiny village and the exchange serves at a guess 200 houses and about 6 businesses (one of which is mine)
I presume it will have to go sub 400 for BT to react?
craigbrass
2mb Service Drop...
Yea, BT's limits are rediculous. I think it was about 500 on a 2mb connection which is just totally stupid.
2mb Service Drop...
Exchange contention.
Even though you may be on a small exchange, it only takes a couple of bandwidth leechers to cause problems for everybody. It could of course be a problem with the ecchange itself. BT arent too quick at providing current exchange information.
And yes, BT wont really move until your speeds hit less than 400, pitiful as that may be.
sophos9
2mb Service Drop...
Mark, Hi
During the day, from home and from testing at work everything seems fine which kinda leads me to believe that this is down to exchange contention
Tried the tests a few mintues ago and they were pretty naff, sub 900. Will try them late tonight! And there I was starting to get an a$$ with plus net, seems its not them at all!!
So, is each exchange allocated a set bandwidth and does it change with the amount of users connected?
I.e... Exchange with an estimated 500 users will be given lesser bandwidth than exchange with 2000?
2mb Service Drop...
Exchange capacity will vary depending on the number of customer it supplies. A small rural exchange will not have the same capacity as one in a large town.
BT have on occasions misjudged projected capacity on some exchanges, therefore if uptake is high customers can experience problems.
You can only hope that BT realise that there are issues with your exchange and upgrade it fairly quickly. In addition and as I mentioned earlier, you maybe unlucky to have a number of high bandwith users on your exchange who are downloading all there is to download from the internet. This will have a detrimental effect on everybody elses speed at that exchange.
sophos9
2mb Service Drop...
Thanks for clarifying that
Im sorry to say that with BT, nothing surprises me....
Will update things as soon as I get some results...
Thanx
craigbrass
2mb Service Drop...
Out of interest, if one user on the exchange is hogging bandwidth, what do BT do?
