2mb Premier Contention
Hey All Cheesy
I am wondering, I am a fairly new plusnet user, and i have gone with the Premier package.
I was wondering about this contention thingy,
Being a premier user do i need to worry about when i download?? like at off peak times, or because i am on this package this is something that i dont need to worry about?
Huge thanks in advance Smiley
yea you wont find that out. I think its a 30:1 (maybe contended to 50:1 by BT but no one will clarify that), there is a "cap" of "reasonable usage" so hey if you think its reasonable to downlaod 24/7 then go for it Smiley
Buz
Thanks for the reply, not to worried what it is at the moment, as speeds are really fantastic, just dont wont it to change thats all
