2mb ADSL and P2P issue
Hi..
Having a 2mb connection, using DC++ was pretty sucsessful for me, reaching maximum speeds that I could...
But recently..my speeds plumit....every file...no matter how what or who I am d/l from...
I have no idea as to why this is..I have no virus or spyware.....and its so bad even my uploads are faster than my download....and that has never happened b4
Any ideasHuh
Cheers
Join the club. Are you using BB plus, which has traffic shaping. Or BB Premier which has no traffic shaping?
Also are normal http/ftp transfers slow?
I am on BB Premier...
and my normal downloads are fine...its just DC++ and up until 2 weeks ago....they were fine...
I have checked for spyware etc..and everything is as it was
Just a thought, are you using XP, and do you have the built in firewall active ?
Regards, John Taylor
Yes I have got XP, but do not have the firewall active...
My downloads are now slower tyhan my uploads...
Incredibley bad!!
Alex
Sad
Have you tried the usual things such as limiting your upload speed etc. Also, have you installed any updates recently from Microsoft ? There were some problems with service pack 2 limiting the number of connections.
I dont limit my upload connections as they are usually so little.
ALso,I have installed Windows SP2, but had the problems long before I installed it.
Sad
