2MB Speed Question
2MB Speed Question
Hello,
Ive just started out on the 2MB ADSL Premier service. Now Im connected at 2.2MbpS and I ran a speed test and this is the result:
1.64 Mbps
IS that normal for 2Mb Broadband?
2MB Speed Question
Yes 100% normal Smiley
2.2Mbps is the Line Speed.
You receive 2Mbps from PlusNet and this can vary a bit.
That is about average speed for 2mb connection.
Remember that speed can increase during non-peak times Smiley
2MB Speed Question
Great stuff!
Im not a dowloader really! As long as its the speed I asked for Im more than happy. So far so good :-)
Optimize your link
You can get through a bit more by tinkering with the MTU, more detail here:
http://portal.plus.net/central/forums/viewtopic.php?t=12116
2MB Speed Question
My 1st evening on plus.net, download a few small apps and browsed the net for several hours (premier account ) totalled 60Mb....
My first evening: 87.99MB
Hey,
My first evening was 87.99MB last Friday.
It seems like a healthy average.
The next day it was 230.46MB, windows update on two machines.
2MB Speed Question
Thats what I can only think of that would be a big download for me. Updating software and OS..
2MB Speed Question
Well, the BB is slower tonight.
Your download speed : 546 kbps or 68.2 KB/sec.
Your upload speed : 234 kbps or 29.3 KB/sec.
2MB Speed Question
Hallo,
I am using 2MB Premier second week. I tested Sped with various web pages and getting speed around 610(min)-920kbps(max). Usually evening time.
I checked with DSLzoneuk.nEt that I am around 453m straight line from my exchange MYARM.
From my point of view it is very poor speed as I expected to be around 1.5MB as ADSL can reach pretty good sped to 2km from exchange.
I am on the extention line (6m) from main BT socket.
Any suggestions? Shoul I report this to Support?
2MB Speed Question
Download Speed: 1107 kbps (138.4 KB/sec transfer rate)
Upload Speed: 186 kbps (23.3 KB/sec transfer rate)
That isnt very good for 2MBHuh I thought it should be about 1.6 to 1.7 Mbps?Huh
2MB Speed Question
1024 tonight...
This happening to others then?
2MB Speed Question
Do a BT SPEEDTEST before you contact support!
http://usertools.plus.net/tutorials/id/27
2MB Speed Question
he speed test has completed on test server speedtester1.nat.bt.com for user and you have downloaded a 1.7Mb file at a speed of
529 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Your IP address is (removed ), your browser is reported as being Mozilla 5.0 and is running on Windows XP.
BT would regard the speed ranges shown below as normal service:
For 250kbps End Users speeds between 50 - 250kbps.
For 500kbps End Users speeds between 100 - 500kbps.
For 1000kbps End Users speeds between 200 - 1000kbps.
For 2000kbps End Users speeds between 400 - 2000kbps.
munsy
2MB Speed Question
greetings welcome to plusnet there is no going back sir, that was just a dream.
2MB Speed Question
Yup,
Although PN will agree that your not seeing the speed you ought to get, their hands are tied as BT has outlined anything between 400 and 2000 is perfectly normal.
Just keep trying and best thing to do is to set your router up for 1 nights testing.
Hopefully you will catch a couple of occassions where it goes below the 400 mark or awefully close.
I will edit this post again when I have found the script concered. Not made by me but rather by another member of the PN user base but nice and neat all the same.
