2MB ADSL Broadband
2MB ADSL Broadband
I have just upgraded my broadband to 2MB, the downstream is checked to 2MB but the upstream stayed the same before when I was on 512k. I just want to know whether this is normal or not, many thanks.
2MB ADSL Broadband
Yes, unfortunately getting a higher upload speed is very expensive at the moment. So even if you upgrade to a faster downstream, you'll be stuck with the old upstream of 256Kbits/second Smiley
2MB ADSL Broadband
thank you for your reply.
