2 mbps from 1mbps
2 mbps from 1mbps
hi
i am thinking of uupgrading from 1mbps to 2mbps
i am currently on ADSL Home Worker Pro 1Mb (Annual)
and the one i want to swap to is the one below is thier any diffrence in the services apart from the speed and price which is cheaper than what im paying for 1 mbps
can i upgade to this package its cheaper and 2mb and its still 20-1 connection
is thier any diffrences from the one im on now?
Broadband Home [2Mb Premier (Monthly)] ADSL 2048/256 £60.00 £34.03 £102.09 £408.36
later
david
2 mbps from 1mbps
The Broadband Home 2Mb is provided on a 50:1 contention (20:1 only until the BT product is finalised).
The Broadband home product also has the Spam and Anti-virus included.
2 mbps from 1mbps
you mean the 20-1 it says it is will be 50-1 later?
or am i confused?
is this a better or worse option
thanks
2 mbps from 1mbps
IIRC, it does not say 20:1 at all, or even 50:1, because of the very reason it will change once the new product is complete.
Where did you find it saying 20:1?
2 mbps from 1mbps
hi
i get info of these specs als link at bottom where i get it from
thanks
ISP Name: PlusNet
Product Name: Broadband Home [2Mb Premier (Annual)]
Technology: Asymmetric Digital Subscriber Line (ADSL)
Wholesale Package: Office 2000 from British Telecommunications
Service Information & Options
Maximum Contention: 20 to 1.
IP Addressing: Static
Number of IPs: Up to 16 with justification
Transparent Cache: None
NAT: None
PAT: None
Webspace Provided: Yes
Domain Included: No
Email Account: Yes
Backup Dialup: Yes
and linkhttp://www.adslguide.org.uk/isps/prodinfo.asp?id=1041
2 mbps from 1mbps
Well, that info is incorrect, but has been updated at damned last.
I get the feeling they they have had to give at least that info for now, to get it listed.
I am sure a PlusNet bod will be able to answer this one officialy for you though.
2 mbps from 1mbps
is thier anywhere on plusnet i can check the specs on various options
i have loked but cannot find info
later
david
2 mbps from 1mbps
Yes, the more info link on the main product page takes you to http://www.plus.net/info2/residential/info_broadband_home.html where details can be found at the bottom.
It's not as clear as it used to be but that's the best they have.
2 mbps from 1mbps
hi thanks for link
but it does not state anywhere what connection it is 50-1 or 20-1 a major selling point and this needs applying to the details
to let people know what they getting
later
david
2 mbps from 1mbps
Philip explained this point earlier.
In pratice, the contention ratio is less of an issue now, with Capacity Based Charging (CBC) methods being used which allows the ISP to control the contention rather than BT. Also in practice BT and not getting anywhere near the contention limits imposed and in many paces (except in the high population density areas) there is little difference between 20:1 and 50:1 anyway
2 mbps from 1mbps
so basically i will be better off swapping to this new option?
later
david
2 mbps from 1mbps
I have no idea as it is your choice. Remember the homeworker Pro is for business use, the broadband home is for residential use and as your use is not changing, PN may still consider the homeworker pro product is the one you should still be on.
I would however wait and see what the new homeworker pro products based on CBC will be like. I would also suggest you wait a bit longer for the regrade fees to reduce which should happen in a few days.
2 mbps from 1mbps
thanks for info will wait a few days for this new pricing
later
david
