2 mb speed and connection?
my connection has just been upgraded from 512 to 2mb. it doesn't seem any quicker to me though. Am I missing something, should I be changing any settings?
Did a couple of speed tests in a few mins:
30-09-2004 18:47:10 1687.4
30-09-2004 18:46:51 1463
30-09-2004 18:46:30 1846.9
30-09-2004 18:45:48 1272.9
Also, I now keep losing the connection. The little icon in the right corner of the screen keeps going to "ADSL connecting" and when I try to connect I get the message "the modem has reported an error". Any ideas?Huh
Those speed tests susggest you are connecteed at 2Mb.
What MTU & RWIN values have you set in windows? See the MTU tweak for info on this and for alternatves to try. Tweaking your MTU can improve your speeds - also when setting the vaues with DrTCP, set the RAS MTU as well as some ADSL modems use this figure.
it was 1458 but just changed it to 1478 and 63272 ..... not really noticed any difference though.
got these tweak test results:
. Your Tweakable Settings:
Receive Window (RWIN): 63272
Window Scaling: off
Path MTU Discovery: ON
RFC1323 Window Scaling: OFF
RFC1323 Time Stamping: OFF
Selective Acks: ON
MSS requested: 1438
TTL: unknown
TTL remaining: 115
2. Test 146000 byte download
Actual data bytes sent: 146000
Actual data packets: 102
Max packet sent (MTU): 1478
Max packet recd (MTU): 1478
Retransmitted data packets: 0
sacks you sent: 0
pushed data pkts: 5
data transmit time: 0.868 secs
our max idletime: 135.0 ms
transfer rate: 92506 bytes/sec
transfer rate: 740 kbits/sec
This is not a speed test!
transfer efficiency: 100%
advice as follows:
Notes and recommendations:
Change MTU to 1500 (FAQ #652, #695)
Choose RWIN between 20132 and 50330 (FAQ #586)
download/use DRTCP .. (FAQ #57Cool
Read the tweak FAQ
i've now followed the tweak test advice but still no difference.
I'm getting fed up .................. the connection problem is still happening. Very random loss of connection. I've looked at the modem properties and it tells me it is working fine. it is the one i got from plusnet ..... when its not connected the first 2 red lights flash together (rdy & link). help ... someone!! :x
Time to raise a ticket so plusnet / BT can invastigate it.
did you change your modem from G.Lite to G.DMT :?:
just curious :?:
how do you do that? i saw that on another post but cannot see where i can change it if i need to. is mine, an original as supplied by plusnet for 512 connection, likely to need changing? cheers.
jeez, my speed just dropped from 2Mb to 256k Evil this is unbelievable, when will BT get thier bloomin fingers out Sad
ADSLGuide Results..
Downstream 271 Kbps (33.9 KB/sec) 292 Kbps (inc. overheads)
Upstream 243 Kbps (30.4 KB/sec) 262 Kbps (inc. overheads)
WinMTR Results
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| 192.168.1.1 - 0 | 779 | 779 | 0 | 0 | 0 | 0 |
| lo1.plusnet.pth-ag2.plus.net - 1 | 779 | 772 | 15 | 26 | 47 | 32 |
| gi1-2.vlan3.pth-gw4.plus.net - 2 | 779 | 771 | 15 | 29 | 63 | 32 |
| ge0-1-0-22.ptn-gw1.plus.net - 1 | 778 | 771 | 16 | 30 | 79 | 32 |
| lon1-10.nildram.net - 1 | 778 | 775 | 16 | 31 | 47 | 32 |
| lon1-9.nildram.net - 2 | 778 | 769 | 15 | 30 | 47 | 32 |
| jolt-gw.nildram.net - 2 | 778 | 769 | 16 | 30 | 47 | 32 |
| clarity.jolt.co.uk - 2 | 778 | 770 | 15 | 31 | 32 | 32 |
|________________________________________________|______|______|______|______|______|______|
WinMTR - 0.8. Copyleft @2000-2002 Vasile Laurentiu Stanimir ( stanimir@cr.nivis.com )
Man I'm not happy, I thought we fixed this [Expletive's Removed] Last Year Evil
I know this could be a bit simple but have you checked you have microfilters in all your sockets that you use. Yesterday my 2mbps (which i only just got) was only about 512 speed, then realised this morn that id left a phone socket without a filter and tried it after putting one in and bam up to 2mbps. just an idea
Chris
Speed variable
Well...
I'm getting variable speeds - and although they're back up tday it feels sluggish. Oh - and connection still dropping unpredictably.
Speeds:
Date
Speed Achieved (kbps)
06-10-2004 17:49:24
1928.9
06-10-2004 17:49:05
1929
06-10-2004 17:48:44
1899.2
06-10-2004 17:48:20
1929.5
06-10-2004 17:48:02
1930.1
06-10-2004 17:47:35
1891
05-10-2004 22:39:29
1417.3
05-10-2004 22:27:13
1285.4
05-10-2004 22:26:27
1596.3
05-10-2004 22:25:58
1243.2
05-10-2004 22:22:34
1108.7
05-10-2004 22:18:36
1348.2
05-10-2004 22:18:01
1268.8
05-10-2004 22:17:22
1183.6
01-10-2004 23:41:59
1892.9
D
i've checked loads of stuff.
GDMT thing
uninstalled and reinstalled modem
used an old lead to go straight into phone socket
unplugged phone
MTU tweaks
Nothing seems to work! Still seems slow and random loss of connection ...... sometimes only connected for 10 seconds and never longer than 4 or 5 mins.
