1mb speed problems
1mb speed problems
any one help with speed problem, when recently on 512 I was getting speed of 380mbps, since regrading to 1 mb the connection has only gone up to 480mbps! I am using a D Link adsl wireless router and I have had BT check the line a couple of days ago, any help appreciated
1mb speed problems
yes o.oo twice yesterday and one 0.00 speed today Cry never been this bad
holdtight
1mb speed problems
Some more info on your system and setup would help!
Are you sure your regrade has gone through as this is 512 speeds?
did you recieve an email from plusnet to say your regrade had
been done?
if the answer is yes check your exchange status Here
if all is well at the exchange double check all your settings and hardware
are all set correctly
also have a look here: ADSL Troubleshooting
1mb speed problems
yes regrade has gone through and my exchange is ok, my pc is and old P3 though, i am changing it at present, the problem is that speed is slower than when i was on 512
