1mb ADSL Upgrade problem
Just had my ADSL regraded from 512k to 1mb. My router recognises that the line rate has changed and is showing 1152kbps downstream and 288 upstream. Only problem is there is absolutely no change in download speeds if anything it is actually slower than when I was on 512k. Very disappointing. Am I doing anything wrong?
1st Welcome to the forums!
2nd If I had a £1 for every time someone posted with your problems I'd be rich! :lol:
3rd the problem is that PN are throttling you ring up (number at bottom of page) tell them you are syncing at 1MB and ask to be unthrottled they flick a switch and you reboot ur equipment viola u r now on 1MB Cool
4th anyway of making 3rd a stock answer so when someone posts who's being throttled you just hit a button and the forums put into your post exactly what is needed to remedy the situation! :lol:
Thanks ever so much. A happy ending. Problem resolved! Cheesy
