1gb Limit on BB+
1gb Limit on BB+
Hi I though bb+ was unlimited usage. When i went to check my usage my meter only goes up to 1gb. :?
1gb Limit on BB+
If you read the text just below the bar it states:
The figure displayed at the higher end of the scale is an indication of how much data transfer you have used. If you use more data transfer this figure will automatically increase
I.e. the scale will adjust as you use more.
1gb Limit on BB+
Ah ok thanks Cheesy
