1Mb to 2Mb Upgrade
1Mb to 2Mb Upgrade
Morning!
Requested an upgrade to a 2Mb line yesterday and was very surprised this morning to find my router status showing the following:
DownStream Connection Speed 2272 kbps
UpStream Connection Speed 288 kbps
So being an excitable chap I immediately started a speed test and it was only downloading at 1Mb speeds.
All help / advice / suggestions / explanations will be gratefully received.
Dave
1Mb to 2Mb Upgrade
Your line is likely throttled by PN as they won't have found out from BT yet that the upgrade is completed. Usually a quick call to Customer Services can get the throttle lifted.
1Mb to 2Mb Upgrade
Groovy, thanks for the reply.
