1Mb Regrade - same DSLAM Port?
Lorian
If I regrade from 512Kbps (home) to 1Mbs (home) will the regrade involve changing the port I'm on on the DSLAM?
Jc.
I seem to recall somewhere in the past reading that this is a software change on the DSLAM, and does not involve your line being moved.
But then again, I might be wrong !
For the most part, line cards are configurable. However, BT run a pretty much customised network, which may mean they do not use mixed speed environments.
In some exchanges they may move you, in others they may not.
