155mb Fat Pipe Testing here :)
Dear Support,
I'm just logged on to network, and i can tell you i got connected straight away!. thats one good thing, iam now going to put this to the test (whithout hogging anything) on the upstream and downstream, i will post back tral user time results here when i'm done, and not false results from adsl.org, as i find adsl.org speed test isn't very acurate.
Will post back some results shortly. Smiley
Been waiting a long time and looking forward for the 155mb fat pipe to be in place.. so this i'm happy to do.
Jason
RE: 155mb Fat Pipe Testing here :)
Test one complete.
realtime user Upstream is: 30.33 K or 303 K/bs
a great improvemnt!
this was a constant MPEG upstream to live365,
i pushed it to the max 56K user end for DSL/cable users,
something i couldn't do before as it would never go
any higher than 16.00 K or 6 K/bs without constant dropouts.
Now going to test Downstream and post some results after im done.
Jason
RESULTS ARE GOOD Wink
Done with proper testing program (not adsl.org)
SESSION START: 28/08/2002 13:33:33
Start Test: 28/08/2002 13:33:44
Test Type: Download 500 kilobytes
Operating System: Windows XP
-------------Settings Used------------
[D-Link DSL-200 USB ADSL Modem(WAN)] Maximum Transfer Unit: 1500
[Realtek RTL8139/810X Family Fast Ethernet NIC] Maximum Transfer Unit: 1500
[1394 Net Adapter] Maximum Transfer Unit: 1500
Tcp Receive Window: 256960
Time To Live: 64
Black Hole Detection: False
Auto-Detect Maximum Transfer Unit: True
Maximum number of simultaneous HTTP 1.0 Connections: 10
Maximum number of simultaneous HTTP 1.1 Connections: 8
Tcp Options: 1 - Window Scaling but no Timestamp Options
Fast Retransmission and Recovery support value: 3
Support for Selective Acknowledgements: True
Data Transfer Start: 28/08/2002 13:33:46
Data Transfer Complete: 28/08/2002 13:33:56
--->Total Data Received: 500.54 kilobytes
--->Time to Complete Transfer: 00:00:09:625
--->Average Speed: 51.63 kilobytes per second
--->Peak Speed: 133.68 kilobytes per second
Start Test: 28/08/2002 13:34:18
Test Type: Download 1 megabyte
Time To Live: 64
Data Transfer Start: 28/08/2002 13:34:19
Data Transfer Complete: 28/08/2002 13:34:38
--->Total Data Received: 1025.20 kilobytes
--->Time to Complete Transfer: 00:00:18:563
--->Average Speed: 55.30 kilobytes per second
--->Peak Speed: 147.88 kilobytes per second
As you cab see i'm getting my max Upsteam of 30K and max of 55.30 K Downstream, it could be 60 K.. But who cares right!
I know i'm getting my full up and down at this present time, well done PlusNet!.
Hope it still works this good at peak user times! Smiley <-- happy now
Jason
And just for the sake of others who might moan,
here is a speed test from ADSL ORG
Downstream 465 Kbps (58.1 KB/sec) 534 Kbps (inc. overheads)
Upstream 240 Kbps (30.0 KB/sec) 276 Kbps (inc. overheads)
So you can see it's good!. and i'm getting the max for my account.
Jason
And again here is another ADSL org speed test just to confirm that i'm getting super speeds now.
Broadband Speed Test Results
Results from your most recent broadband speed test recorded on 28 August 2002 at 13:52:49.
Your Connection
Direction Actual Speed True Speed
Upstream 236 Kbps (29.5 KB/sec) 271 Kbps (inc. overheads)
Will test everything again after 6pm, but i don't see there being a problem, everything is great!
I read some posts here from earlier, by a couple of newbies.. someone needs to tell them that you don't actually get 512 K downloads!!
LOL i wish that you did Wink
For the new people here on ADSL 500 packages you can expect '30 K' upstream and around '60 K' max downstream. This is the correct speeds for ADSL 500. You can't get 512 K downloads here, well not with a 500 account!!.
Jason
Hi!
It is so good to see that everything is going well, especially after the dispair of some over the past few weeks.
Keep on with the reports, and don't forget if anybody notices any problems after the new central pipe install please let us know.
Good luck and I hope the fast speeds continue!
Kind Regards,
Russell.
| Russell Till.......................Unmetered & ADSL solutions
| Technical Support .......................for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ---- My Referrals - It pays to recommend PlusNet ----
> Hi!
> Kind Regards,
> Russell.
Er... Can I have my ADSL now please?
I hate to say it... It doesn't seem any faster to me....
Numion.com is telling me 80KByte/sec - which is pretty close to the average the last week.
A month ago it usually gave me 200KBytes/sec
My latest TraceRT is
C:\>tracert news.bbc.co.uk
Tracing route to newswww.bbc.net.uk [212.58.226.40]
over a maximum of 30 hops:
1 10 ms <10 ms <10 ms 192.168.0.1
2 20 ms 90 ms 70 ms 105.core.plus.net [212.159.1.105]
3 191 ms 200 ms 180 ms 109.core.plus.net [212.159.1.109]
4 231 ms 450 ms 211 ms dolpiaza.core.telehouse.plus.net [212.159.1.60]
5 180 ms 180 ms 180 ms rt-linx-a.thdo.bbc.co.uk [195.66.224.103]
6 180 ms 180 ms 191 ms news.bbc.co.uk [212.58.226.40]
Some alarmingly high numbers there....
Steve
tracert to bbc and ping test to dns server. Not good.
2 14 ms 16 ms 16 ms 105.core.plus.net [212.159.1.105]
3 246 ms 249 ms 251 ms 109.core.plus.net [212.159.1.109]
4 268 ms 265 ms 278 ms dolpiaza.core.telehouse.plus.net [212.159.1.60]
5 277 ms 289 ms 294 ms rt-linx-a.thdo.bbc.co.uk [195.66.224.103]
6 300 ms 297 ms 299 ms www.bbc.net.uk [212.58.224.121]
Trace complete.
C:\WINDOWS>ping 212.159.11.150
Pinging 212.159.11.150 with 32 bytes of data:
Reply from 212.159.11.150: bytes=32 time=318ms TTL=248
Reply from 212.159.11.150: bytes=32 time=342ms TTL=248
Reply from 212.159.11.150: bytes=32 time=325ms TTL=248
Reply from 212.159.11.150: bytes=32 time=304ms TTL=248
Ping statistics for 212.159.11.150:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 304ms, Maximum = 342ms, Average = 322ms
What happened to 23ms ping times to the server?
