155 MB fat pipe update for PlusNet
Support
I posted a thread here this morning,
with all my speed tests and everything was @ max.
well i have been busy most of tonight, so just back on there before bed and i see everyone comlaining as usual,
whats up with people, will you never be happy till your DSL is going super sonic??!!
I tested everything this morning and just there,
and it's still working fine.
all my slow connections are gone, and i'm even connecting first time.. every time now.
Here is a ping:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
ping 212.159.11.150
Pinging 212.159.11.150 with 32 bytes of data:
Reply from 212.159.11.150: bytes=32 time=34ms TTL=249
Reply from 212.159.11.150: bytes=32 time=33ms TTL=249
Reply from 212.159.11.150: bytes=32 time=35ms TTL=249
Ping statistics for 212.159.11.150:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 33ms, Maximum = 35ms, Average = 34ms
I don't see what folk are moaning about.. thats fast!!
Now heres another speed test (not adsl guide)
SESSION START: 29/08/2002 05:04:36
Start Test: 29/08/2002 05:04:44
Test Type: Download 1 megabyte
Operating System: Windows XP
-------------Settings Used------------
[D-Link DSL-200 USB ADSL Modem(WAN)] Maximum Transfer Unit: 1500
[Realtek RTL8139/810X Family Fast Ethernet NIC] Maximum Transfer Unit: 1500
[1394 Net Adapter] Maximum Transfer Unit: 1500
Tcp Receive Window: 256960
Time To Live: 64
Black Hole Detection: False
Auto-Detect Maximum Transfer Unit: True
Maximum number of simultaneous HTTP 1.0 Connections: 10
Maximum number of simultaneous HTTP 1.1 Connections: 8
Tcp Options: 1 - Window Scaling but no Timestamp Options
Fast Retransmission and Recovery support value: 3
Support for Selective Acknowledgements: True
Data Transfer Start: 29/08/2002 05:04:45
Data Transfer Complete: 29/08/2002 05:05:06
--->Total Data Received: 1023.50 kilobytes
--->Time to Complete Transfer: 00:00:20:437
--->Average Speed: 49.65 kilobytes per second
--->Peak Speed: 153.48 kilobytes per second
As you can see it is still fast.
So why you folk moaning still.
G night! Smiley
Jason
RE: 155 MB fat pipe update for PlusNet
Tracing route to portal.plus.net [212.159.8.137]
over a maximum of 30 hops:
1 29 ms 28 ms 29 ms 105.core.plus.net [212.159.1.105]
2 29 ms 28 ms 29 ms 109.core.plus.net [212.159.1.109]
3 30 ms 30 ms 30 ms dolpiaza.core.telehouse.plus.net [212.159.1.114]
4 34 ms 34 ms 37 ms atm.core.plus.net [212.159.1.65]
5 37 ms 35 ms 37 ms vlan25.rhogan1.core.quay.plus.net [212.159.15.25
0]
6 36 ms 35 ms 37 ms alteon1.core.quay.plus.net [212.159.15.230]
7 36 ms 35 ms 38 ms portal.plus.net [212.159.8.137]
Trace complete.
Maybe i'm very lucky.. but i have no more problems.
appart from it's way past bedtime!
Night.
Jason
While I'm very happy for you that your speed (latency) is good clearly it is not the case for evryone. I can asure people (I)have more to do than write e-m's to PLusnet. Have a look at some of the speeds from others that are "moaning" and compare those to yours. I think you will find that for the most part people's tracert's are often into 3 significant figures!! and that is ten times slower than your ave 32ms. I having been one of the moaners have just posted a congrat's to PlusNet though. Cred, where credit due etc. Cheeri. Aaaa....Haaaaa.
my ping times on that server
Pinging 212.159.8.137 with 32 bytes of data:
Reply from 212.159.8.137: bytes=32 time=85ms TTL=249
Reply from 212.159.8.137: bytes=32 time=59ms TTL=249
Reply from 212.159.8.137: bytes=32 time=106ms TTL=249
Reply from 212.159.8.137: bytes=32 time=145ms TTL=249
Ping statistics for 212.159.8.137:
Minimum = 59ms, Maximum = 145ms, Average = 98ms
usual is it
Pinging 212.159.1.105 with 32 bytes of data:
Reply from 212.159.1.105: bytes=32 time=145ms TTL=64
Reply from 212.159.1.105: bytes=32 time=149ms TTL=64
Reply from 212.159.1.105: bytes=32 time=143ms TTL=64
Reply from 212.159.1.105: bytes=32 time=140ms TTL=64
Ping statistics for 212.159.1.105:
Minimum = 140ms, Maximum = 149ms, Average = 144ms
this is not fast.
plusnetsux
C:\WINNT>ping 212.159.1.105
Reply from 212.159.1.105: bytes=32 time=10ms TTL=64
Minimum = 10ms, Maximum = 10ms, Average = 10ms
C:\WINNT>
Smiley Smiley yes at last !
> Support
> Here is a ping:
> ping 212.159.11.150
> Time To Live: 64
> G night! Smiley
> Jason
hi you may be getting fast pings but there was a problem yesterday evening plusnet acknowledged this and did get it fixed there was no problem with data transfer rates but when you try to play a fps game it becomes impossible if your ping goes over 150.on a jolt uk server last night which is normally around 50 it had reached 400 at one point.you may use your adsl for data transfers I but some of us do use it primarily for gaming you have all had your gripes about slow transfer rates as last month or two so when there is a speed issue regarding server response times please let us have our gripe.cheers stevie ps well done plusnet for getting it sorted as soon as you could
OK everyone, well i was on quite early yesterday morning, i couldn't wait to see if the long awaited 'fat pipe' was going to work.
and it did, i connect first time every time now, before that i was same as everyone else trying to connect for many many times, plus my pings were same as yourselves and i couldn't use very much of anything b/c of the dropouts all the time, but honestly everything has imporoved to normal now for me, i just thought some ppl were moaning at not going fast enough again, some ppl are like this, they will never be happy.. even if the service was 1mb they still want it faster!.
Well thats what i was thiking at first, it was late, i didn't read all posts here at the time, but i have now!.. and i can't inderstand why you are all still having problems, do you think it might be BT realated more than PlusNet.. since my connection is ok now?.
If PlusNet still had a problem i'd be slow aswell, like i was before.. maybe it's BT, depending on where you live, i know BT will be doing work soon on the Fujisu cards at the exchanges, from sept 1st to sept 10th alot of exchanges are getting fixed.
My exchange my due to be done on the 4th sep. 2am-6am.
Someone posted a URL for all this work here last week, if you look it's on one of the threads.
I'll do a few more pings for you to compare before i go:
C:\Documents and Settings\Jason>ping -n 10 portal.plus.net
Pinging portal.plus.net [212.159.8.137] with 32 bytes of data:
Reply from 212.159.8.137: bytes=32 time=90ms TTL=249
Reply from 212.159.8.137: bytes=32 time=75ms TTL=249
Reply from 212.159.8.137: bytes=32 time=89ms TTL=249
Reply from 212.159.8.137: bytes=32 time=73ms TTL=249
Reply from 212.159.8.137: bytes=32 time=94ms TTL=249
Reply from 212.159.8.137: bytes=32 time=74ms TTL=249
Reply from 212.159.8.137: bytes=32 time=82ms TTL=249
Reply from 212.159.8.137: bytes=32 time=65ms TTL=249
Reply from 212.159.8.137: bytes=32 time=57ms TTL=249
Reply from 212.159.8.137: bytes=32 time=41ms TTL=249
Packets: Sent = 10, Received = 10, Lost = 0 (0% loss),
Minimum = 41ms, Maximum = 94ms, Average = 74ms
C:\Documents and Settings\Jason>tracert portal.plus.net
1 29 ms 29 ms 27 ms 105.core.plus.net [212.159.1.105]
2 114 ms 122 ms 128 ms 109.core.plus.net [212.159.1.109]
3 131 ms 121 ms 122 ms dolpiaza.core.telehouse.plus.net [212.159.1.60]
4 125 ms 119 ms 117 ms atm.core.plus.net [212.159.1.65]
5 98 ms 91 ms 95 ms 250.core01.access.plus.net.uk [212.159.15.250]
6 120 ms 108 ms 112 ms alteon1.core.quay.plus.net [212.159.15.230]
7 117 ms 116 ms 113 ms portal.plus.net [212.159.8.137]
Trace complete.
Well it's not as good a response as yesterday right enough.
Speed test now:
SESSION START: 29/08/2002 13:18:01
Start Test: 29/08/2002 13:18:06
Time To Live: 64
Data Transfer Start: 29/08/2002 13:18:07
Data Transfer Complete: 29/08/2002 13:18:28
--->Total Data Received: 1023.47 kilobytes
--->Time to Complete Transfer: 00:00:20:250
--->Average Speed: 50.07 kilobytes per second
--->Peak Speed: 75.34 kilobytes per second
ADSL GUIde test now:
Broadband Speed Test Results
Results from your most recent broadband speed test recorded on 29 August 2002 at 13:23:06.
Your Connection
Direction Actual Speed True Speed
Downstream 324 Kbps (40.5 KB/sec) 372 Kbps (inc. overheads)
Upstream 239 Kbps (29.9 KB/sec) 274 Kbps (inc. overheads)
Speed is ok, but i understand about the slow responses if you're a game player.
Hope it all fixes for you folks soon Smiley
believe me i HAVE been there.. and for many many weeks, i know how frustrating it gets.
Fingers crossed for ya Smiley
Jason
